Command not recognized on switch WS-C2960G-48TC-L
Simone C
Good morning all,
I'm here because while trying to launch the following command:
(config-if)authentication event server dead action authorize voice
the device keeps saying to me the "invalid input detected" error". I've tried in other switches 2960 models and the command is recognized properly.
Perhaps it is not supported on this model or software version? (current release installed Version 12.2(58)SE2)
Thank you for your help!
Authentication event server dead action authorize vlan vlan-id
Authentication event server dead action authorize voice
BOTH same if you use vlan id of voice in first command.
When the server down the sw authz will use vlan id of voice.
11 Replies 11
M02@rt37
Hello @Simone C
check the IOS version of the other switches 2960 models where this command is available. 15.x version ?
If yes upgrade to 15.x release also.
Best regards
Hello M02@rt37
I tried to launch the same command into switches with 12.2.x release, and like @balaji.bandi said and confirmed, i managed to launch the command and it works as per devices with 12.2(33) and later. I may have typing something wrong.
Thank u very much!
Sure i see last voice command may be wrong, correct that syntax and let us know if that works.
if that works for you let us know the outcome and input.
BB
DanielP211
Hello!
Are the other switches the same model? And are you on the same version? I belive the commands are not available in version 12.2...
BR
****Kindly rate all useful posts*****
Hello @DanielP211.
Other switches have different release, but all with the same family of 12.2.x I'm now reading @balaji.bandi suggestions.
Thank you and thanks also to M02@rt37 for the hints and suggestions
Great news!
You're welcome @Simone C
Best regards
balaji.bandi
Release
Modification
12.2(33)SXI  This command was introduced.
Make sure syntax is correct - always use ? after each word, so IOS Guide you what syntax is correct.
authentication event server dead action authorize vlan vlan-id
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/a1/sec-a1-cr-book/sec-cr-a3.html#wp5040908190
BB
Hello Balaji,
Ok i managed to look up fot the syntax and i noticed the error occours while adding the parameter "voice" into the command, since it is not recognized , as per shown here:
(config-if)#authentication event server dead action authorize ?
vlan Configure Critical Authorization VLAN
<cr>
If I'm right and following your step, I have to declare the voice vlan ID in order to perform the command. Could it be correct?
I then tried in other switched with same SW version and model, and it is the same output.
Thank you for your kind help!
that should work for you.
BB
Simone C
Hello! Thank you very much for the explaination!
