01-25-2021 05:55 AM
Hello.
I would like to ask if it is possible to configure, on a cisco router, Active Direcotry authentications for SNMP v3.
The cisco routers are 1841 / 1921 / C891-F
Thank you in advance.
Solved! Go to Solution.
01-25-2021 07:47 AM
- I don't think that is possible in the sense that snmp v3 users must always be 'local'
M.
01-25-2021 07:01 AM
Good question - not that i am aware of - sure good thinking.
you can consider using AAA
01-25-2021 07:47 AM
M.
01-26-2021 11:02 PM
Thank you all for your answers .
