Connection Management > Administration > Create Connection
getwithrob
Level 3
Level 3
When creating connections under Connection Managment you click create and then type in an application name and a version. After that, you have to enter a Server name. This is my problem; the system already fills in the http:// then you have to enter a name or ip address and you can also use a port number. I would like to enter a server name beginnging with https:// and not http://.
Note: The server is setup to use SSL
nhabib
Level 9
Level 9
Go ahead and create the connection using http:, go to NMSROOT/htdocs/XML/Public/maintree, and edit the corresponding .lf file to change the URL there.
You'll have to restart JRunProxyServer afterwards.
