Controller Configuration Backup Error
enricos
Visitor
Hello All,
New to network, got this error message on our backup Job in Prime and not sure if there is a work around or fix for this. Nothing was changed on the backup config so not sure what was the trigger. It does say wrong value.
"Exception during ConfigBackup: (IP Address). MEDIATION-7,FileTransferConfigOptions (IP Address),downloadDataType,Bad value for downloadDataType in FileTransferConfigOptions[3008005_(IP Address)]: Wrong value"
Thanks for the help
10 Replies 10
Mark Elsen
             - What controller model and software version ? What version of Cisco Prime are you using ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
1. i would check the remote IP address accessble
2. Do you have enough space
check below document can guide you :
https://mrncciew.com/2014/01/12/wlc-config-backup-using-prime/
BB
enricos
Visitor
Hello Balaji,
Thanks for the help. Will look into this link you provided.
Best Regards,
Enrico
WojciechW
Visitor
I am trying to download running config file of AIR-CT2504-K9 8.0.115.0 via snmp to tftp server but getting following error:
Error in packet.
Reason: noCreation (That table does not support row creation or that object can not ever be created)
Any ideas ?
          >I am trying to download running config file of AIR-CT2504-K9 8.0.115.0 via snmp to tftp server but getting following error:
                  Not supported ,
 M.
Thank You,
is it not supported by this model or software version ?
 - The intended backup via snmp method is not supported in general on aireos based controllers ,
 M.
May be uplift the code or use what available is best approach.
BB
via SNMP - not that i know that works.
Try different mode suggested on the document.
BB
thank You so much for Your response. Following that:  "mode suggested on the document" - can You elaborate ? Especially what document ?
