Credentials
schadmin
Level 3
Level 3
Is there a way to verify credentials for a group of devices? I would like to see if the credentials are correct.
nhabib
Level 11
Level 11
I suggest exporting your inventory to a CSV file and checking the credential that way.
If you are unsure how to export the inventory, please provide the product and its version number.
barryjones
Community Member
Depending on version - you can go to RME/ADMINISTRATION/INVENTORY/CHECK DEVICE ATTR. or VIEW CHECK RESULTS. This will do a comparison of the device - what's in the cred. inventory db and what creds are on the device.
