08-26-2012 11:39 PM
After doing a fresh install of Cisco Prime 4.1 and rebooting the server 'Cisco Prime Daemon Manager' service won't start. Startup type is 'Auto'. Server has been rebooted twice and I have tried 'net start crmdmgtd' without success.
C:\Users\NetAdmin>net start crmdmgtd
The Cisco Prime Daemon Manager service is starting.
The Cisco Prime Daemon Manager service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
C:\Users\NetAdmin>net helpmsg 3534
C:\Users\NetAdmin>
08-31-2012 04:58 AM
I have the same issue - how did this one get fixed ??
09-01-2012 11:17 PM
Find and run the resetcasuser.exe in CSCOpx\setup\support. Receate the casuser with a password that meets the standard of your domain.
Something has tampered with he permissions of the casuser account that runs the LMS processes.
A domain policy server is able to do this kind of thing.
Make sure all services are set to manual startup except the daemon manager, the syslog , tftp and RCP service.
Cheers,
Michel
09-03-2012 06:38 AM
I am suspicious that a policy was pushed impacting this -
The fix is as follows -
Stop all services relating to CiscoWorks/LMS/CiscoPrime
Run - CSCOpx\setup\support\resetcasuser.exe
reset to old passpord seems to work fine.
Start the Daemon Manager Process
Wait about 30 minutes - all services seem ok.
01-23-2014 04:36 AM
I tried this but I am still not able to get the Cisco prime Daemon manager to start.
01-23-2014 05:59 AM
Nicholas,
Ideally you should start a new thread for your problem as this is two year old issue.
The symptoms may be similar, but the reason may be different.
When you start the daemon, after error, share the syslog.log content, for us to see what is the exact error.
-Thanks
Vinod
"Encourage Contributors. Rate them for Free "
01-23-2014 06:59 AM
It is windows 2008, do you want the event logs? They dont seem to have any errors.
01-23-2014 07:17 AM
I need to see following output:
> Output when you enter command : net start crmdmgtd (on command prompt)
> Last 100 lines of NMSROOT/log/syslog.log
> event logs, if anything pertainign to Ciscoworks processes.
Try following things as well:
# Make casuser a member of adminitrators group.
#Make sure you have swap properly and manually configured (twice of RMA):
1. Right click on "Computer" and select "Properties." Click on "Advanced System Settings."
2. Choose the "Advanced" tab and click "Settings," under "Performance."
3. Choose the "Advanced" tab and click "Change" under "Virtual Memory."
4. Uncheck "Automatically Manage Paging File Size" for all drives.
5. Click "Custom Size" and enter the amount of swap space in MB (megabytes). Click "Set" and then "OK" three times to return to the desktop.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
01-24-2014 01:54 AM
Vinod Arya
Making casuser an administrator has done the trick. The odd thing here is that this server was build back in July and it just suddenly stopped working. Maybe someone had thought that casuser shouldnt be in that group and kicked it.
Thank you!
Nick
