Device Center in RME 4.3.1
marekbudzisz
Aftetr upgrade RME from 4.3.0 to 4.3.1 some posibilities in Device Center has disappeared . I have  got only Create Collector in Managment Tasks tab. I can't see when has inventory and archive config  been polling.
Screen is in attachment.
Martin Ermel
this is CSCtc21648. You need to contact TAC to get the patch.
CSCtc21648            Bug Details
RME links and info missing from Device Center after upgrade
Symptom:
The Resource Manager Essentials tasks and  reports are missing from the Device Center.  Additionally, all  RME-related device information is also omitted.
Conditions:
This occurs after applying the RME 4.3.1 EnergyWise service pack.
Workaround:
A workaround is available by contacting the TAC
Martin Ermel
Symptom:
Conditions:
Workaround:
It works
Marek
