09-09-2011 10:06 AM
im using CISCO PRIME LMS 4.1 for manage my network, i ran a device discovery job using a ping sweep on the ip ranges of my network, ie 192.168.1.0/24, 192.168.2.0/24 and so on... the discovery found all my devices, but it discovered duplicate devices with illegal ip Addresses, ie
ip device
192.168.1.255 S1
192.168.2.0 S1
192.168.2.1 S1 (the real address)
all in reachable status.
i dont undestad why the program adds that repeated illegal addresses.. someone can help me with that issue??
how can i run the device discovery to avoid this problem?
Many Thanks.
Solved! Go to Solution.
09-09-2011 12:43 PM
Julio,
Don't let LMS decide on what IP address it will manage the device.
For example, let LMS do a lookup of the sysname in DNS, then it will use the IP address coming back from the DNS as management IP.
This is what I do to avoid this.
But I also feel that LMS should be bright enough to never manage the same device twice. I think Campus DFM or RME will eventually figure out the 2 devices are the same, but they can't "fix" what is wrong in the DCR.
Cheers,
Michel
09-09-2011 12:43 PM
Julio,
Cheers,
Michel
09-12-2011 09:49 AM
Thanks Michel.
i thought was a error in my configuration or related about what i was doing for the discovery. so is a LMS's bug.
