Device Package for 3750X Switches
mshipley_2
Is there a Cisco Works Device Package for the new 3750X switches?  Just bought
159 3750X-48PS-S switches to go with over 1000 3750G switches.
ihatelogin
LMS 3.2 doesnt support the device out of the box but I downloaded a device update for the software download section for the 3750x which got it working in ciscoview.  Believe this was the update i used for ciscoview.  Probably an update for the other parts of LMS as well.
Thanks for the correction - I missed them when checking my earlier post.
3750X's ARE on both the LMS3.2 support list and the LMS4.0 / 4.01 support lists.
As you mentioned, applying the latest device support package will add them to the fold.
