04-20-2011 06:03 AM
Hi...
I have a problem with DFM device discovery, While rediscovering devices all the devices are in questioned state - snmp timeout. But inventory and config management is working. Its running on a windows 2008-r2 server. I have looked at the local firewall and there are no dropps there. If i run device verification credentials job, its run succesfully.
Reegards Lasse
04-23-2011 01:54 AM
Are your devices in DNS?
Enable debugs for all inventory and device management, and rediscover the devices.
Admin > System > Debug Settings > Discovery Logging Configuration
Admin > System > Debug Settings > Fault Debugging Settings
Get the logs from
04-28-2011 12:53 AM
04-30-2011 10:53 PM
I see the following errors repeated in the logs:
Inventory Services/SNMP Timeout
Questioned Devices in Inventory Services/Insufficient Credentials
05-02-2011 01:13 AM
I using snmp version 2 and i all ready done a packet capture. I cant see any thing wrong in the capture file. When i looking at collector status.
Discovery Success
Data Collection Success
User Tracking Success
Inventory Success
Conftig Collection Success
Fault Discovery Failure
/Lasse
08-29-2011 07:59 AM
Has anyone found a fix for this as I am seeing the same thing. If I disable the firewall it works fine. I have compared the required ports with the firewall and it appears they are all there.
