Discards in cisco 3850 switch
santosh kumar
We recently implemented Cisco 3850 switches and we are observing huge discards on the interfaces. I have below default configuration but not seeing anywhere applied.
    show policy-map
  Policy Map system-cpp-policy
    Class system-cpp-police-data
     police rate 200 pps
       conform-action transmit
       exceed-action drop
    Class system-cpp-police-sys-data
     police rate 100 pps
       exceed-action drop
    Class system-cpp-police-sw-forward
     police rate 1000 pps
       exceed-action drop
    Class system-cpp-police-multicast
     police rate 500 pps
       exceed-action drop
    Class system-cpp-police-multicast-end-station
     police rate 2000 pps
       exceed-action drop
    Class system-cpp-police-punt-webauth
    Class system-cpp-police-l2-control
    Class system-cpp-police-routing-control
     police rate 1800 pps
       exceed-action drop
    Class system-cpp-police-control-low-priority
    Class system-cpp-police-wireless-priority1
    Class system-cpp-police-wireless-priority2
    Class system-cpp-police-wireless-priority3-4-5
    Class system-cpp-police-topology-control
    Class system-cpp-police-dot1x-auth
    Class system-cpp-police-protocol-snooping
    Class system-cpp-police-forus
    Class system-cpp-default
  Policy Map port_child_policy
    Class non-client-nrt-class
      bandwidth remaining ratio 10
Need suggestion to fix the issue.
Santosh
balaji.bandi
Can you post show version and post the interface you have discards and explain what is connected to that port ( you observed as discards ) ?
BB
I have DB Server, KVM, ESX and i see even in one of the KVM which is not in use.
sh ver
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.8, RELEASE SOFTWARE (fc3)
Gi1/0/18 2669491 0 138 7753
Gi1/0/19 2638140 0 138 7752
Gi1/0/20 247496132 2373205 4332 0
Gi1/0/21 1723863386110 6453774374 2432 770
Gi1/0/22 2018372044010 6497421165 2468 69
Gi1/0/23 5079884500376 15544269001 2570 836
Gi1/0/24 3691907278386 13135983053 2405 287
Gi1/0/25 0 0 0 0
Gi1/0/26 3677109661933 9279357543 0 0
Gi1/0/27 767508600915 1895615165 0 0
Gi1/0/28 7276494 163 0 26945
Gi1/0/29 1025410798379 994604768 114415 3080243
Gi1/0/30 11111158138 129596676 114742 1049
Gi1/0/31 45674287686 241197735 114500 211
Gi1/0/32 719101276 9849542 16553 0
Gi1/0/33 2669148 0 138 7752
Gi1/0/34 2638405 0 137 7753
Gi1/0/35 6954254 0 0 20099
Gi1/0/36 6924498 0 0 20013
Port InOctets InUcastPkts InMcastPkts InBcastPkts
Gi1/0/37 91784934701 137772212 0 18881
Gi1/0/38 131549750963 451652859 0 537767
Gi1/0/39 377498585216 386254916 0 229288
Gi1/0/40 184057263129 362193555 0 308779
Gi1/0/41 0 0 0 0
Gi1/0/42 12170905 145 184080 0
Gi1/0/43 7044906 0 0 20361
Gi1/0/44 60 0 0 0
Gi1/0/45 42655345717903 96142337395 16958410 1895865
Gi1/0/46 0 0 0 0
Gi1/0/47 17160306665293 43064591055 42752 1905
Gi1/0/48 0 0 0 0
Gi1/1/1 72604770019 84152762 184074 1434547
Gi1/1/2 0 0 0 0
with the older switch does this happen?
I have discards but not like now. Now i am seeing huge discards on most of the  ports which are connected to KVM, ESX or DB
Gi1/0/25 0 0 0 0
Gi1/0/41 0 0 0 0
Gi1/0/44 60 0 0 0
Gi1/0/46 0 0 0 0
Gi1/0/48 0 0 0 0
Gi1/1/2 0 0 0 0
