01-06-2005 04:06 AM
I want to know whether 1841 router is supported on Cisco View v5.5.
Since Campus Manager 3.3 and CiscoView 5.5 are in the same bundle of CiscoWorks LMS version 2.2.and it is supported on Campus Manager 3.3.
Solved! Go to Solution.
01-06-2005 12:21 PM
Goto CCO CiscoView device package download page and see if there is a package listed for your router for CV 5.5, if there is then install it to add the support. If there isn't any listed, then it is not supported by CV 5.5 currently.
01-06-2005 12:21 PM
01-06-2005 07:22 PM
Acyually the problem is tha 1841 router is not listed in the download page for CV5.5 But for Campus Manager 3.3 it ssays tha this router is compatible. Also both these comes in the same suite i.e. LMS 2.2
So does it means that this router is not compatible with CV5.5 and may be added in future???
