EEM Custom Trap to Single Host
matthewathom
I'm currently sending SNMP to multiple hosts.  I have utilized the EEM to create custom traps following the guidance provided here:
https://supportforums.cisco.com/docs/DOC-11745
If possible I would like to send the custom traps to only one of the SNMP hosts that I am sending standard traps to.  The applet seems to send traps to all hosts regardless of what trap types are configured in the snmp-server host command.  Is there a way to configure the custom traps to be sent to only one of the multiple hosts I have configured?
2 Accepted Solutions
Joe Clarke
No, this is not possible.  The traps will be sent to all configured hosts as they are injected into the SNMP subsystem as opposed to being sent directly from EEM.
Those traps will only be sent to hosts with event-manager traps configured.
Joe Clarke
If instead of utilizing custom traps I utlized the following:
action label snmp-trap intdata1 integer
would the same be true or would I be able to specify which host the traps are sent to via the notification-type parameter in the host command?
snmp-server host ip address version 3 noauth username event-manager
Ok...thanks for your help.
