EEM "event track" not supported on Catalyst 9500 ??
gnijs
Level 4
Level 4
I am trying to trigger an EEM applet based on a track object.
However, running Fuji 16.8.1a:
(config)# event manager applet test
(config-applet)#event track ?
% Unrecognized command
Any workaround ? I don't want to rely on timers. My tracked object is a boolean combination of tracked interface line states, so it triggers immediately. The EEM applet also needs to fire immediately (i don't want to use timer based EEM applet)
dp@sig4
Base event on syslog entry for the track change:
event syslog pattern "%TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down"
Other option is write a python script using APIs.
