EEM Script : Copy cli_result on file
Maurizio Bau
Frequent Visitor
Frequent Visitor
Hi all
I need to be save "show ip int bri | ex down" and other similar show command on a single file without using TCL ( i have 7609 with SRD5 IOS)
I read in other post that can't possibile to manage a "douBle pipe"
NOT WORKING
action 1.0 cli command "show ip int bri | ex down | append sup-bootdisk:interface.txt"
I try to use a following script like this discussion https://supportforums.cisco.com/thread/2101880, but i don't have any file on sup-bootdisk
EEM Script
event manager applet showproc
event timer watchdog time 20
action 1.0 cli command "enable"
action 1.1 cli command "show process cpu | ex 0.00"
action 1.2 cli command "more $_cli_result | APPEND sup-bootdisk:showproc.txt"
What's my error?
Maurizio Baù
Joe Clarke
This applet will not work.  The "more" command only works with files.  No, you cannot do double pipes with applets.
You could move to Tcl to do the filtering you want:
::cisco::eem::event_register_timer watchdog time 20
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_exec $cli1(fd) "show proc cpu | exc 0.00"} _cli_result] {
set fd [open "sup-bootdisk:showproc.txt" a]
puts $fd $_cli_result
close $fd
# Close open cli before exit.
catch {cli_close $cli1(fd) $cli1(tty_id)} result
