Bookmark
Subscribe
3870
EEM Script for matching IP address
jon_panes24
hi all,
I need to do an EEM script that when I do a "show ip interface brief | ex unassigned" it will list just the IP address.
Here is the output of my "show ip interface brief | ex unassigned"
Interface                  IP-Address             OK?              Method           Status          Protocol
FastEthernet0/0      30.1.1.2                  YES              manual            up                up
Serial2/0                 40.1.1.2                  YES              manual            up                up
Loopback1              3.3.3.3                    YES              manual            up                up
heres my current script, it only prints 30.1.1.2. Why doesnt it match the other IP addresses ?
event manager applet 10
event none sync yes
action 1 cli command "en"
action 2 cli command "show ip int br | ex una"
action 3 regexp "([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)" "$_cli_result" ip
action 5 puts "$ip"
I want the output to be
30.1.1.2
40.1.1.2
3.3.3.3
Something like that.
Jonathan
Dan Frey
EEM needs to iterate over the output and extract the ip address.
action 010 cli command "enable"
action 020 cli command "show ip int brief | ex unass"
action 030 foreach line "$_cli_result"
action 040 regexp "([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)" "$line" ip
action 045 if $_regexp_result eq "1"
action 050 puts "$ip"
action 060 end
action 070 end
Dan Frey
action 060 end
action 070 end
Thanks Daniel. Works like a charm :)
Hi Daniel,
I see you provided this EEM script ( LONG TIME AGO) to extract IP addresses which works wonderfully.
Is it possible to have each extracted IP address assigned to a different variable that I can call later on in my EEM script???
Thank you
Frank
