06-09-2009 12:50 PM
Is "ip flow egress" supported on this platform? Is it possible to collect bidir stats if Netflow configured as follows:
interface vlan ...
ip flow ingress
ip flow egress
06-09-2009 01:40 PM
Rather, it depends on the version of the IOS you're running:
http://www.cisco.com/en/US/docs/ios/netflow/command/reference/nf_01.html#wp1012951
" If your router is running Cisco IOS release 12.2(14)S or a later release, or Cisco IOS Release 12.2(15)T or a later release, NetFlow accounting might be enabled through the use of the ip flow ingress command instead of the ip route-cache flow command.
12.3(11)T
The egress keyword was added."
Unless there's new advances, I don't think you can apply both "ingress" and "egress" on the same interface. NetFlow is based on unidirectional flow records.
04-27-2011 03:17 AM
Hi yjdabear,
are you sure that egress netflow is supported on 7600? Because I have configured "ip flow ingress" and "ip flow egress" on a sub interface. My collector can only read ingress data. I check using "show ip cache flow" and only see ingress flow. Also, take a look at this email thread http://puck.nether.net/pipermail/cisco-nsp/2007-July/041977.html. Cisco documentation sometimes is confusing that I often have doubts about them. Please if anybody can confirm?
Prima
