10-08-2021 03:51 AM - edited 10-08-2021 04:50 AM
IOS XE Gibraltar 16.12.x (Catalyst 3650 Switches) support ERSPAN.
Can I send ERSPAN destination to a local RSPAN vlan on the destination switch. The command are available but I could not find any documentation to support the theory.
CORE- (config) #monitor session 66?
destination SPAN destination interface or VLAN
filter SPAN filter VLAN
source SPAN source interface, VLAN
type Type of monitor session
CORE- (config) #monitor session 66 destination?
interface SPAN destination interface
remote SPAN destination Remote
CORE- (config) #monitor session 66 destination remote?
vlan Remote SPAN destination RSPAN VLAN
CORE- (config) #monitor session 66 destination remote vlan?
<1006-4094> Remote SPAN destination extended RSPAN VLAN number
<2-1001> Remote SPAN destination RSPAN VLAN number
My idea is to create a RSPAN vlan on the destination switch and send all ERSPAN data to the RSPAN vlan and then pass the RSPAN vlan on a trunk to my virtual server.
10-14-2021 01:02 AM
=> no (RSPAN) VLAN mentioned here only physical ports
10-14-2021 01:12 AM
maybe this nformation from balaji.bandi helps
Source IP where you are capturing the monitor session
destination when you like to sniff the traffic or mirror the traffic
a good example here : https://mrncciew.com/2017/08/17/configuring-erspan/
you can find config example :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/configuration_guide/nmgmt/b_169_nmgmt_9500_cg/configuring_erspan.html
