10-13-2021 11:52 AM
Trying to get prime to communicate with tools.cisco.com for smart licensing, but it always fails. In the shell when ever it use
nslookup tools.cisco.com it adds the domain-name...ie tools.cisco.com.domain-name which causes it to fail. If I remove domain-name I get another resolver error. Ping to local gateway, and IP address of tools.cisco.com all work.
Solved! Go to Solution.
10-13-2021 12:39 PM
Look at the some bug and workaround :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx06532?rfs=iqvred
if this is not case kindly show us the config and problem.
worth check this thread :
10-13-2021 12:39 PM
10-13-2021 12:48 PM
Disabling DNSSEC did the trick.
