Experiences with Master/Slave-Model in LMS 2.5
lotmueller
Hi there,
does anybody of you having experiences with Master/Slave (Distriuted) Mgmt-Model in LMS 2.5?
Does this model support different Mgmt-Domains sync'ing each other?
Will CM,RME,DFM data be sync'd?
Thanks for any feedback and experiences
Best Regards
Lothar
pradeepde
Level 5
Level 5
Yes, the master/slave management model does support different management domains synchrinising with each other. Also CM, RME, and DFM data will also be synchronised.
So, if the master gets hosed, we can count on it synchronizing with the slave, and be back in business quickly?
