03-11-2021 01:55 AM
Hi, Could somebody help with the commands to factory default a 5508-x, I have reset 5505s etc but never a 5508 and the commands seems slightly different. I have searched but cannot seem to find any documentation to help.
03-11-2021 01:58 AM
Do you have access to to console - then connect to console cable :
config t
config factory-default
once you have prompt back
reload
reload save-config noconfirm
=====️ Preenayamo Vasudevam ️=====
03-11-2021 02:08 AM
Im in console as thats how I'd reset a 5505 for example but those don't seem to work for a 5508.
03-11-2021 03:28 AM - edited 03-11-2021 03:30 AM
can you post show run - what error you getting ?
Options1 :
configure factory-default 10.1.1.151 255.255.255.0
Option 2 :
or use Another way to check this 8 button (reset)
03-11-2021 04:38 AM
Looking at it I am in the firepower CLi and not ASA CLi thats where the confusion is coming from, any ideas how I get out of this or reset firepower?
03-11-2021 05:21 AM
there is 2 options :
1. re-image the box with fresh firepower
2 follow the below guide :
https://integratingit.wordpress.com/2019/12/22/ftd-factory-reset/
