fh_parse_var: could not find environment variable: hour
Josiah Inubio
Hi guys, I just found an error on using the script and the action doesn't work. It says there's something wrong with the variable "hour". How can I resolve this? Thanks.
Script:
ROUTER(config)#event manager applet cell2
ROUTER(config-applet)# event syslog pattern "Modem in HWIC slot 0/2 is DOWN"
ROUTER(config-applet)# action 1.0 cli command "enable"
ROUTER(config-applet)# action 1.1 cli command "show clock"
ROUTER(config-applet)# action 1.2 regexp "([0-9]+):[0-9]:[0-9]" $_cli_result match hour
ROUTER(config-applet)# action 1.3 if $hour ge 17
ROUTER(config-applet)# action 1.4 reload
ROUTER(config-applet)# action 1.5 end
Error:
Aug 25 08:23:57.362: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Aug 25 08:23:57.690: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: hour
0 Replies 0
