Guidelines/Best Practices for Configuring Logging ?
getwithrob
Level 3
Level 3
I'm looking for some guidelines and best practices to configure logging on IOS devices, Fastswitch and Catalyst switches. I also want to configure the devices to send the messages to a syslog server.
spremkumar
Level 9
Level 9
hi
would suggest to go thru this link which gives u up the guidelines in configuring the basic logging in your equipments.
http://www.cisco.com/en/US/partner/products/hw/switches/ps628/products_configuration_guide_chapter09186a00800d84c6.html
if u still need more info would suggest again to do a search in cisco.com with the keywords as configuirng logging in switches which will yield lots n lots of helpful links...
regds
