Hi all,
we brought a Cisco 881W-GN-E-K9 and we use it as main router.
We have this network architecture:
- the WAN (FastEthernet4 interface) is connected to the 192.168.0.x network
- all the ethernet interfaces (FastEthernet 0-3) and the wlan are in 10.0.0.0 network using a VLan
We have some problems:
- we set static DNS entries in the Router:
ip host Waters 10.0.0.1
ip host Barrett 10.0.0.2
ip host Mason 10.0.0.20
ip host Wright 10.0.0.21
However, the ping Mason it's not working....
- we activate a NAT for the 8080 port on the 10.0.0.21 pc but it does not works:
ip nat inside source static tcp 10.0.0.21 8080 A.B.C.D 8080 extendable
someone can explain were we are falling?
Following the router configuration:
Current configuration : 6948 bytes
version 15.1
no service pad
hostname Waters
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1382020822
REMOVED!!!
crypto pki certificate chain TP-self-signed-1382020822
REMOVED!!!
ip source-route
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.0.1 10.0.0.99
ip dhcp pool DHCP
import all
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
dns-server 10.0.0.1
lease 0 10
ip cef
ip host CiscoRouter 10.0.0.1
ip host SamsungML3050 10.0.0.91
ip host CiscoAP 10.0.0.2
ip host EpsonSX440W 10.0.0.90
ip host RouterAP 10.0.0.2
ip host Router 10.0.0.1
ip name-server 192.168.0.1
ip name-server 8.8.8.8
ip name-server 10.0.0.1
no ipv6 cef
vpdn enable
vpdn-group 1
REMOVED!!!
license udi pid CISCO881W-GN-E-K9 sn REMOVED!!!
username routeradmin privilege 15 secret REMOVED!!!
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 192.168.0.253 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Vlan1
ip nat inside
peer default ip address dhcp-pool DHCP
no keepalive
ppp encrypt mppe 128
ppp authentication ms-chap ms-chap-v2
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
ip nat inside
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
description BLABLABLA
ip address 10.0.0.1 255.0.0.0
ip nat inside
ip nat enable
ip tcp adjust-mss 1452
ip local pool PPTP-Pool 10.0.1.10 10.0.1.99
ip default-gateway 10.0.0.1
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip default-network 192.168.0.0
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 23 permit 10.0.0.0 0.255.255.255
no cdp run
Leonardo,
What do you mean when you say the static entry for Mason is not working? Do you mean that when you type "ping Mason" it times out? What happens when you try and ping the actual IP address of Mason ( 10.0.0.20 ) - does that work?
Regarding the NAT - I assume that the outside address (removed from config above) is in the 192.168.0.x range?
If you try and hit the outside NAT address and do "show ip nat translations" and "debug ip nat" do you see anything?
Hi mfurnival,
thank for your answer...
inline my outlines:
yes, the ping to 10.0.0.20 works ok while ping mason times out....
hooo... thanks, this issue was solved: i was mapping the outside ip address (156.x.y.z) and not the 192.168.0.x... thank you.
Leonardo
Seems weird. Can you do the following and post the output please?
#show hosts
#ping Mason
#sh arp
#ping 10.0.0.20
#sh arp
Hi, after several attepts, I discover that:
ping mason. ==> works (note the final dot !!!)
So, I think that it depends on domain name: in our network the default domain is not set...
so I have that:
ping mason ==> doesn't work
ping 10.0.0.20 ==> works
I think that since the domain is not set, the name that the router is able to resolve is mason.[empty]
and it does not resolve mason (without final dot)
