How i forwoard some syslog device to other Server from CiscoWork 2.2 ?
Hi All
I would like to forward syslog to other Server for only few device not for all.
How i configure at CiscoWork2.2 ?
Ittiphol Chanaphai
Joe Clarke
Syslog forwarding is not something that is easily doable in LMS. It would be better to either configure multiple syslog destinations on your devices, or send syslog messages to a syslog relay that can then send them to multiple servers.
I'll offer this but I am not sure if the same applies to LMS2.2 (We are using 2.5 at the moment).
The way I have done this is to use Notification Services in the Device Fault Manager (DFM). Under Notification Groups simply add a group and the select the devices you want to forward the messages from. When you have completete the creation of the group go into the Syslog Notification and then add a new syslog notification subscription and enter the details of the syslog server that you want to receive the messages.
As I said, this may be completely irrelevant on LMS 2.2.
