Bookmark
Subscribe
4786
How many bytes per ! when transferring using SCP? HTTP?
cgcomscore
I am transferring files from a Linux server to my switches for upgrades, etc.  I despise TFTP for many, many reasons and use SCP whenever possible.  But, I'm not sure how many bytes are transferred every time the "progress meter" shows another ! in the terminal.  I'm also not sure how to change that value.  Google has not found any relevant information about this either.
What does the community think?
5 Replies 5
Francesco Molino
Each exclamation mark means a successful transfer of ten packets (1 packet = 512 bytes)
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Thanks!  I was wondering where you found that documented since my Google searches were not working.
I think you can find something in Cisco tftp documentation but i learned that at the beginning of my career that's why i answered :-)
Francesco
mwalters
Quick note that the equation has been changed in more recent IOS versions to 256KB per ! exclamation mark.
~256KB per '!'
Loading xxxxxxxx.bin from 192.168.159.1 (via FastEthernet0/0):
[OK - 32738244 bytes]
32738244 / 128 = 255767.53125
