How to configure Ciscoworks to backup a Netacs appliance?
REUBEN CHIN
I've got a TAC case already opened on this, but if anyone knows how I can get CiscoWorks to do this it would be greatly appreciated.
Simply put, I would like the Netacs appliance to appear as all the other devices I have within Ciscoworks.  Of course the Netacs already preforms an automatic backup to a specified remote location, but I was wondering or would like to keep all the configs / inventory managed within CiscoWorks.
Anyways, if it's not doable I'll live with the current setup but just had to ask to explore the possibilities if any.
Reuben
Nael Mohammad
Level 5
Level 5
If it's not listed  in the Supported Device Table for LMS 3.2, it's not supported.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
Thanks Nael.
Just spoke with Cisco TAC and they said the ACS device is not supported.   I'll check your doc as well - good advice.  Thank you again.
Reuben
