How to get inline power via SNMP for Catalyt 9k
fhk-cwempe
I want to monitor the PoE-usage of your new Catalyst 9000 (like C9400) switches.
For older Catalyst 4500 I used this OID: 1.3.6.1.4.1.9.9.117.1.1.4.1.4.16
Multiplied with 0.5 (for 5V) I get the load in Watt.
But this OID does not work for the new generation.
I found this OID: .1.3.6.1.2.1.105.1.3.1.1.4
Which returns the load per LineCard.
But I want to get the load for the whole chassis, like this:
Switch#sh power inline
Available:8130.0(w)  Used:328.1(w)  Remaining:7801.9(w)
Is there an OID for this?
fhk-cwempe
I just found this OID: 1.3.6.1.4.1.9.9.402.1.3.1.4
see: https://mibs.observium.org/mib/CISCO-POWER-ETHERNET-EXT-MIB/#
I get the expected total values.
But they are still mapped to the installed LineCards.
SNMPv2-SMI::enterprises.9.9.402.1.3.1.4.1 = Gauge32: 433153
SNMPv2-SMI::enterprises.9.9.402.1.3.1.4.2 = Gauge32: 433153
SNMPv2-SMI::enterprises.9.9.402.1.3.1.4.7 = Gauge32: 433153
SNMPv2-SMI::enterprises.9.9.402.1.3.1.4.8 = Gauge32: 433153
Available:7840.0(w)  Used:433.2(w)  Remaining:7406.8(w)
I am looking for an OID with an index that is the same for each of our switches.
Here it is ".1", ".2", ".7 and ".8".
But what about a switch where only Slot 3 and 9 have LineCards.
Then my template would not work.
Maybe I need to invest time to make the template dynamic and check which LineCards dop exist.
