Is there a way to change the interface speed in Cisco Prime LMS. I need to change the speed as the High Utilization alerts are directly dependent onh it. The default speeds on ADSL ports are configured for 1 MB but the actual link between the ISP is more than that. I could easily change this speed in Solarwinds so I suspect there should be a way to do it in LMS as well.
