Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to upgrade isr 4451 fuji ios?
baselzind
Level 6
Level 6
i have  a isr 4451-x router with fuji 16.9.2 which i need to upgrade to 16.9.3 , i read the upgrade manual which was very confusing and unclear so i was wondering is it just like the old method of doing the below
no boot system
then
boot system bootflash:isr4400-universalk9.16.09.03.SPA.bin
then reload? and the router would come up with the new image?
you need boot system flash bootflash:imagename
Router# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)# boot system flash bootflash:isr4400-universalk9.03.10.00.S.153-3.S-ext.SPA.bin
Router(config)# config-reg 0x2102
Router(config)# exit
Router# show run | include boot
boot-start-marker
boot-end-marker
Router# copy run start
Destination filename [startup-config]?
Building configuration...
[OK]
Router# reload
15 Replies 15
balaji.bandi
you do the tradional way here is the document :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_0101.html
First i boot with New IOS and test all working as expecte, then delete old one copy the new image to flash and change to boot variable.
make sure you read  the release notes before upgrade.
BB
So the method i mentioned works?
boot-start-marker
boot-end-marker
[OK]
Router# reload
So these steps should be enough to upgrade to 16.9.3 in my case?
yes it works. do this on maintenance window, it require reboot the device.
BB
Thank you alot , i read something in the upgrade process called consolidated or something do you know what it means?
Managing and Configuring a Consolidated Package Using copy and boot Commands
To upgrade a consolidated package, copy the consolidated package to the bootflash: directory on the router using the copy command. After making this copy of the consolidated package, configure the router to boot using the consolidated package file.
The following example shows the consolidated package file being copied to the bootflash: file system via TFTP. The config register is then set to boot using boot system commands, and the boot system commands instruct the router to boot using the consolidated package stored in the bootflash: file system. The new configuration is then saved using the copy running-config startup-config command, and the system is then reloaded to complete the process.
Router# dir bootflash:
Directory of bootflash:/
11 drwx 16384 Dec 4 2007 04:32:46 -08:00 lost+found
86401 drwx 4096 Dec 4 2007 06:06:24 -08:00 .ssh
14401 drwx 4096 Dec 4 2007 06:06:36 -08:00 .rollback_timer
28801 drwx 4096 Mar 18 2008 17:31:17 -07:00 .prst_sync
43201 drwx 4096 Dec 4 2007 04:34:45 -08:00 .installer
928862208 bytes total (712273920 bytes free)
Router# copy tftp: bootflash:
Address or name of remote host []? 172.17.16.81
Source filename []? /auto/tftp-users/user/isr4400-universalk9.03.10.00.S.153-3.S-ext.SPA.bin
Destination filename [isr4400-universalk9.03.10.00.S.153-3.S-ext.SPA.bin]?
Accessing
tftp://172.17.16.81//auto/tftp-users/user/isr4400-universalk9.03.10.00.S.153-3.S-ext.SPA.bin
Loading /auto/tftp-users/user/isr4400-universalk9.03.10.00.S.153-3.S-ext.SPA.bin from
172.17.16.81 (via GigabitEthernet0):
[OK - 208904396 bytes]
208904396 bytes copied in 330.453 secs (632176 bytes/sec)
12 -rw- 208904396 May 28 2008 16:17:34 -07:00
928862208 bytes total (503156736 bytes free)
boot-start-marker
boot-end-marker
[OK]
Router# reload
BB
yes thats from the doc , consolidated upgrade
Leo Laohoo
Has anyone read the Release Notes?
Is the router doing any NAT? If the router is doing NAT, make sure you're aware of CSCvo36188.
can i upgrade directly to Gibraltar-16.10.2?
Read the Release Notes and see if a ROMMON needs to be upgraded or not.
But is there any different steps for upgrading from fuji ver to gibraltar ver?
Did anyone read the Release Notes?
As suggest worth reading the relase notes always when you upgrade. most of the steps already mentioned required ROMMON Upgrade or not, what is the system requirement.
BB
