Invalid commands in 1941 ?
bern46
I'm doing some tests with a 1941 router and setting up dhcp.
While inside a dhcp pool I get an error with the lease command:
router(config)#ip dhcp pool NET1
router(dhcp-config)#lease 10
% Invalid input detected at '^' marker.
Also the clear ip dhcp binding it's giving an error as if it was invalid.
Both seen in the 1941 documentation: https://www.manualslib.com/manual/1198349/Cisco-1941w.html?page=343#manual
This is only for some tests, at the end I think I'll have DHCP in a dedicated server.
Thanks and regards.
2 Accepted Solutions
@bern46
unfortunately packet tracer not support this command.
Good luck
KB
balaji.bandi
5 Replies 5
@bern46
are you using real IOS or packet tracer device?
Good luck
KB
Packet tracer !
@bern46
Good luck
KB
How do you exactly know which commands are valid in PKT and which ones not ? Just by experience ... ?
Thanks a lot !
balaji.bandi
