IOS CLI command to obtain the DHCP reservations for a specific VRF
Waterbird
I'm looking for a CLI command that can find the DHCP reservations but limited to a specific VRF.
I know that 'show ip dhcp pool' is how to see these configured manual reservations (if they are configured).
I know that 'show run | include hardware\-address' will obtain the configured reservation information only
But what I'm needing help with is a command that grabs only the reservations for a specific VRF name only.
Perhaps someone knows a way to do this.
Mark Elsen
          - FYI : show ip dhcp vrf <vrf-name> binding *
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you, but I'm wanting to get what manual reservations are configured, which I believe is not necessarily the same as what bindings there are.
Manual reservations can be seen inside configuraion. Here is the configuration of the reservation:
ip dhcp excluded-address 192.168.1.10
ip dhcp pool CLIENT
hardware-address 0034.121b.0c19
host 192.168.1.10 255.255.255.0
vrf SOMETHING
BR
****Kindly rate all useful posts*****
This issue solved?
