IOS XE 17 netflow direction mark not sent
Serge91
Hi all,
On my router it seems not send "direction" mark to collector
balaji.bandi
why do you think so ? do you configuration example. below netflow works fo me all cat 9K switches :
https://www.balajibandi.com/?p=1383
BB
Cristian Matei
  Can you share relevant configuration?
Cristian.
Serge91
flow record FLOW-RECORD
 description record to monitor network traffic
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match interface output
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect transport tcp flags
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
is okay, I used netflow-original, but by documentation it doesn't send direction
how about other information - as i have provided the basic config, start with basic config and see you able to get the outcome ?
what is the destination side using to collect this netflow information (NMS or anything else ?)
for other feature you like to explore read the guide lines :
https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/ntw-servs/b-network-services/m_fnf-fnetflow.html
BB
