ip nbar protocol discovery counts bitrate only in one way
fisko
Hi I setup the ip nbar protocol discovery on my interfaces. When i type "sh ip nbar protocol discovery" I have only inbount counting for all protocols and outbound is always 0. For serial interface the situation is oposite.Can someone explain this?
THANKS!!!!
a-vazquez
Level 6
Level 6
This is because when you enable "ip nbar protocol discovery" on a inbound interface the traffic in that direction will increase and that is shown in the "sh ip nbar protocol discovery". If it is enabled on a outbound interface like serial interface then the traffic in that direction will increase and hence the "out" counter will increase.
Yes but what about replays for a particular protocol.How does that count?
I just see what comming in the ethernet and see what comming out from serial.
How can I see what comming in serial and comming out from ethernet ?
