snmpset vmVlan does not work on active ports
snarf65
L.S.
as above,
when i apply to an inactive port it works fine, since all my ports are active due to wakeonlan capable nic's this is a problem.
pls enlighten me
thanx in advance
Frans Verschoor
Hi Frans,
I'm not finding anything that could contribute to this, can you possibly upgrade one switch to (12.1(22)EA5 or 12.2(25)SEC) and test on that?
If it's successful then you have your answer, if not, it may be time to open a Cisco TAC Case.
Steve
steve.busby
Level 5
Level 5
Frans,
What hardware platform & software version(s) are you seeing this on?
Steve
steve,
currently i'm working on cat3550 with 12.1(13)
is that a known bug?
thanx in advance
Frans
Hi Frans,
Steve
Steve,
Thanx it did the trick
Frans
