Bookmark
Subscribe
2658
IP SLA authentication
Scott Cannon
Hi Guys,
I'm seeking some clarification on the functionality of IP SLA authentication.
I have configured an open ended responder on my network usign the ip sla responder command. I havea few routers using the device for various IP SLA monitors. I am now concerned that this device could be used in an unauthorised manner and wish to implement authentication.
I've added a key-chain to my configuration on the responder as follows:
key chain 1
key 1
key-string password
I then enabled authentication on the responder using the ip sla key-chain 1 command and found that the initiators (without authentication configured) were still communicating with the target.
Maybe I've misconfigured but I dont see it.
Can anyone tell me if this is the normal behaviour and if so what function the authentication provides?
Here's the associated config from the target:
IPSVC_R2#sho run | sect sla
ip sla responder
ip sla key-chain 1
And here from a intiator:
IPSVC_R1#sho run | sect sla
ip sla key-chain 1
ip sla 1
icmp-echo 2.2.2.2 source-interface Loopback1
frequency 5
ip sla schedule 1 life 86400 start-time now
key chain 1
key 1
key-string password
Rgds
Scott
Joe Clarke
The ICMP echo operation does not require a responder-enabled target.  Authentication will come into play for operations like UDP echo and UDP jitter where you need a responder.  For ICMP echo, the target device's IP stack will respond to the echo request.
Joe Clarke
