Is it possible?
getwithrob
Level 3
Level 3
The Detailed Device report will show modules that have a Major or Minor Fault.
Is it possible in RME or Campus (NOT USING DFM) to find ports that are in an errror disabled state?
It would look something like this:
00:21:04: %PM-4-ERR_DISABLE: psecure-violation error detected on Fa0/1, putting Fa0/1 in err-disable state
5 Replies 5
nhabib
Level 9
Level 9
If you can get the switches to send syslog messages for error disabled, then you would be able to use RME.
Do you have an example of the syslog message....severity and facilty?
Thank you.
Here's what I was able to do:
From RME > Configuration Mgmt > Network Show Commands > Batch Reports >, I was able to define a report for show port status, Schedule the Report and run the report.
This of course to find ports that went disabled before I got syslog setup and working on all devices.
