Issue with Priority based QoS
I want to prioritize traffic from/to certain IPs but the code doesn't seem to work...
ip access-list standard APPS
10 permit xx.xx.xx.xx
20 permit xx.xx.xx.xx
30 permit xx.xx.xx.xx
40 permit xx.xx.xx.xx
50 permit xx.xx.xx.xx
60 permit xx.xx.xx.xx
70 permit xx.xx.xx.xx
80 permit xx.xx.xx.xx
90 permit xx.xx.xx.xx
100 permit xx.xx.xx.xx
class-map match-all APPS
match access-group name APPS
policy-map Police
class APPS
priority percent 80
int Gi0/0
service-policy output Police
int Gi0/1
The bandwidth is not defined and cannot be defined on any interface and as such I need to prioritize the traffic as per accesslist APPS. But the code doesn't seem to work and traffic from other IPs seem to consume the same amount of bandwidth....
balaji.bandi
here is the example : test and advise :
Create Extended ACL :
ip access-list extended priority-subnet-bb
permit ip any y.y.y.y 255.255.255.0 ---> if this is destination IP
permit ip x.x.x.x 255.255.255.0 any <----- i this is is source
Then do a class for that ACL:
class-map match-all class-prio-bb
match access-group name priority-subnet-bb
Then put it in a policy:
policy-map QOS-POLICY
class class-prio-bb
priority percent 80
Apply to interface and test.
BB
