Lan Name
Zepster44
Level 3
Level 3
Hopefully this should be an easy solution.
Our physical office network connects to 2 C3560x switches.  When you plug in an ethernet cable to any computer (Mac, Linux, Windows) the network connection shows up as BTA-TEMP.  I am trying to find where I can change that name in the switches since it is not specific to an OS and anyone who plugs in any laptop or desktop, the name shows up as BTA-TEMP.  Anyone have any ideas on how to change this for the entire office?
Mark Elsen
 - You are probably seeing the assigned vlan name for the port. To re-name that you need  more elaborate and basic networking knowledge on creating , and changing vlan's , not at least to mention etc....
 ! M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I am still in the process of trying to figure out where this is coming from.  I contacted the company that owns our router for the fiber coming in and they said that this is something they can change.  I told them if it shows BTA-TEMP to please change it, but if not, then do not touch anything.  I will let you know if this is from the router end.
Jaderson Pessoa
Well, i dindt understood you question.
Could you share your configuration?
Are you receiving dhcp from these devices? What domain is configured? Please, show more detail about your devices.
If you are trying change the description on the ports, try it:
interface g0/1
description namethatyouwant
If you are trying change the name of vlan, try it:
vlan BTA-TEMP
name MYNAME
Jaderson Pessoa
*** Rate All Helpful Responses ***
balaji.bandi
as mentioned @Mark Elsen  it all depends where you getting this information.
we need more information, show VLAN and show interface description output to give you the right direction.
BB
