LMS 2.5 and IIS
r-reed
Can LMS 2.5 exist on Windows 2003 server with IIS?
5 Replies 5
rmushtaq
Level 8
Level 8
Not supported
nhabib
Level 9
Level 9
please elaborate: do you want to run IIS instead of Apache?
No I just want to put up IIS in order to support a second product on the box. I have a large server for LMS and would like to put a second applicaton on it that needs IIS.
this is not a good idea
You'll need to stop and disable IIS during installation of LMS 2.5. The installation checks if there is a running IIS on the system and aborts if there is. After installation you can enable and start IIS again.
Michael.
