LMS 2.5 - Device Attribute Error report no longer exists
iswift
Has any one else come to the same conclusion.
In LMS 2.2 you could run the Check Device Attributes tool in RME to check the device ceredentials in the db.
I can't find any equivalent in the DCR or RME/Campus in 2.5.
Have you found the same ?
Ian.
nhabib
Level 9
Level 9
It is now called Device Credential Verification
It is located in RME -> Devices -> Device Management
