LMS 3.2 Configuration Archival Summary
Wassim Aouadi
Level 4
Level 4
Why does the Failed devices count increases after each unsuccessful archive sync? Is it a display issue?
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
Nael Mohammad
Level 5
Level 5
Its to indicate that you have 5 devices that failed to get their archives and should address the issue by fixing the credentials since its reporting authentication failed.
But it's the same device that failed. Entries are repeated and counted as though they were different devices.
