LMS 3.2 - how to connect to SQL DB and export DCR data?
Got an problem with LMS 3.2/Solaris.
See no devices both in DCR and RME, besides, in RME device counters (Normal/Pending/etc) are equal to current device count, but then you try to select them for any operation, you unsucceed - 0 device selected, no list of devices, unable to export, no ability to do anything.
Upgraded to 3.2 SP1, no change. Spend a lot of time digging through logs at /usr/adm/CSCOpx/logs, find no problems at all. Seems, that some database parts were corrupted.
I decided to reinstall LMS from the scratch, but to do so I need to export the DCR device data and credentials.
Database is alive (dbaccess.pl install going smoothly, then connection with user lmsdatafeed  works and allows to connect and select data from any SQL tool), but this view is not enough for getting from the DCR both device data and credentials.
I have the DB password I set up during installation.
Is there any way to get data I need connecting to LMS database directly with some kind of sysdba SQL database user?
These are the DBA users/DBnames for the various applications that make up LMS 3.2:
Common Services Database
--Database name (dsn)
  cmf
--Database login
  cmfDBA
RME Database
  rmeng
--Database login
  DBA
ANI Database
  ani
--Database login
  cwsiSA
Inventory Database
  dfmInv
--Database login
  itemInvUser
Event Database
  dfmEpm
--Database login
  itemEpmUser
Fault History Database
  dfmFh
--Database login
  itemFhUser
Passwords would be what was assigned during the installation of  LMS. If you need to change these, then the following would apply:
For Solaris:-
/opt/CSCOpx/bin/dbpasswd.pl
Running the above command will reset database password to default.
Usage:
Format1: dbpasswd.pl all
         Change all database passwords.
Format2: dbpasswd.pl listdsn
         List all available data sources in the product.
Format3: dbpasswd.pl dsn=odbc_datasource
         Change the database password.
Format4: dbpasswd.pl dsn=odbc_datasource npwd=new_password
         Change the database password to new_password.
Format5: dbpasswd.pl dsn=odbc_datasource encryption=yes
         Encrypt the database password.
Format6: dbpasswd.pl dsn=odbc_datasource encryption=yes npwd=new_password
         Change the database password and encrypt the database password.
Hth,
Cary
ccube
Review this guide:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/database_schema/guide/dbviews.html
This gives some insights as to what is possible.
Hth,
Cary
It's already reviewed.
If you'll check the initial post, you'll find that "connection with user lmsdatafeed  works and allows to connect and select data from any SQL tool), but this view is not enough for getting from the DCR both device data and credentials".
I need the DBA-level username(s) to connect to DB, I have DBA password but have no DBA usernames for LMS components. Also, the hints on device credential location in DB and tables would be useful.
  cmf
--Database login
  cmfDBA
RME Database
  rmeng
--Database login
  DBA
ANI Database
  ani
--Database login
  cwsiSA
Inventory Database
  dfmInv
--Database login
  itemInvUser
Event Database
  dfmEpm
--Database login
  itemEpmUser
  dfmFh
--Database login
  itemFhUser
For Solaris:-
Usage:
Hth,
Cary
