10-27-2011 01:04 AM
LMS does not start, although the services seem to be started. Find attached the pdshow output and let me know what more you need me to send.
Solved! Go to Solution.
10-30-2011 10:00 AM
Is this a new issue? Please verify your service settings:
Please pay special attention to the 'Manual|Automatic' setting.
10-30-2011 10:00 AM
11-03-2011 04:04 AM
We have decited to format and re-install LMS so i ll close the case. If we are still having the same problem i will let you know
Thank you anyway.
Nicos
11-05-2011 05:50 AM
Sometimes these services don't start because the casuser account has been attacked by a policy server. That server can apply for instance a GPO that does not allow and removes any users that do not exist inside the windows domain.
I that case the server either has to be excluded from the policy or taken outside of the domain.
You can repair casuser setting using the resetcasuser command. That's a lot quicker then reinstalling.
Cheers,
Michel
