LMS 4.0 ERROR PERFORMING SNMP OPERATION
naiewweian
I am using LMS 4.0 and I keep encountering this issue "Error performing SNMP Operation"
Anyone know how to resolve this?
Wei An
Michel Hegeraat
Level 7
Level 7
SNMP V3?
Enable read/write
Cheers,
Michel
5 Replies 5
Michel Hegeraat
Level 7
Level 7
SNMP V3?
Enable read/write
Cheers,
Michel
Hi Michel,
My SNMP v3 configuration is as follow:
snmp-server group spfadmin v3 auth
snmp-server view spfadminview internet.* included
snmp-server trap-source Vlan79
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps flex-links status
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps ether-oam
snmp-server enable traps flash insertion removal
snmp-server enable traps l2tc threshold sys-threshold
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps rep
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps dot1x auth-fail-vlan guest-vlan no-auth-fail-vlan no-guest-vlan
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps entity-diag boot-up-fail hm-test-recover hm-thresh-reached scheduled-test-fail
snmp-server enable traps port-security
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps ethernet evc status create delete
snmp-server enable traps energywise
snmp-server enable traps rtr
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps isis
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps rf
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps errdisable
snmp-server enable traps vlan-membership
snmp-server enable traps mac-notification change move threshold
snmp-server host 173.24.79.21 vrf vrf_MGT informs version 3 auth admin
snmp-server host 173.24.79.21 vrf vrf_MGT password
snmp ifmib ifindex persist
Any idea where I went wrong?
Not all SNMP info is shown in config. "show snmp ?" shows more.
By default you define only a read view. See extract below on how to define a write view.
Cheers,
Michel
snmp-server group
To configure a new Simple Network Management Protocol (SNMP) group, or a table that maps SNMP users to SNMP views, use the snmp-server group command in global configuration mode. To remove a specified SNMP group, use the no form of this command.
snmp-server group group-name {v1 | v2c | v3 {auth | noauth | priv}} [read read-view]  [write write-view] [notify notify-view] [access access-list]
no snmp-server group group-name {v1 | v2c | v3 {auth | noauth | priv}}
Syntax Description
group-name
Specifies the name of the group.
v1
Sets the least secure of the possible SNMP security models.
v2c
Sets the second least secure of the possible SNMP security models. It  allows for the transmission of informs and counter 64, which allows for  integers twice the width of what is normally allowed.
v3
Sets the most secure of the possible SNMP security models.
auth
Specifies authentication of a packet without encrypting it.
noauth
Specifies no authentication of a packet.
priv
Specifies authentication of a packet with encryption.
read read-view
(Optional) Specifies a read view. The read-view argument represents a string (not to exceed 64 characters) that is the  name of the view that enables you to view only the contents of the  agent.
write write-view
(Optional) Specifies a write view. The write-view argument represents a string (not to exceed 64 characters) that is the  name of the view that enables you to enter data and configure the  contents of the agent.
notify notify-view
(Optional) Specifies a notify view. The write-view argument represents a string (not to exceed 64 characters) that is the  name of the view that enables you to specify a notify, inform, or trap.
access access-list
(Optional) Specifies a standard access list. The access-list argument  represents an integer from 1 to 99 that specifies a standard access  list of IP addresses or a string (not to exceed 64 characters) that is  the name of a standard access list of IP addresses.
Hi mic,
did the read/write access but still getting the same error.
Here are my commands
#show run
snmp-server group admin v3 auth read admin write admin notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F
snmp-server community admin RW
snmp-server host 174.24.79.21 vrf vrf_MGT version 3 auth admin snmp-server group admin v3 auth read admin write admin notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F
#show snmp user
User name: admin
Engine ID: 800000090300503DE55569FF
storage-type: nonvolatile        active
Authentication Protocol: SHA
Privacy Protocol: None
Group-name: admin
Anyone ?
