LMS 4.2.2 Device Interface Monitoring
Ian Beck
HI,
On LMS 3.2 there was a way to disable the monitoring of Device Interfaces.
Examples are ISDN30 Channels, which go up and down during calls. I could disable the channel monitor on the relevant device and only monitor the Circuit as this is the main device to monitor.
I can not find the same option in 4.2.2
Could some provide the link.
gudvardur
Monitor -> Fault settings -> Setup -> Fault Device Details
From there you select the device you want do modify.
To be more precise...
https://yourservername/dfm/deviceReports.do?navid=DDV_Asset
gudvardur
Many thanks
