lms 4.2.5 login redirection error
Hubert Kupper
Cisco Prime LMS 4.2.5 running on Windows 2008 R2 server for over a year without errors. After a reboot of the machine, the successful login results in a redirection error message. Any ideas?
Regards, Hubert
Hubert Kupper
All LMS services started successfully. After the login page a error message occours.
I solved the problem. The self signed certificate of LMS was expired! This generates the loop message after login. Setting the date of the server to a day in the valid period of the expired certificate and recreate the certificate solved the error message.
Regards, Hubert
alfred_loo
I have the same problem.  Fixed by using these steps.
1. change the date backwards a few months
2. Restart the services
3. Request for a new certificate (You may have to use a different browser)
5. There should be a prompt to restart the services
6. Stop services
7. Change date back to current.
8. Start services.
http:servername:1741
httpS:servername
