LMS 4: DFM issues
gunarserdmanis
As suggested by Joseph Clarke, I started a new thread regarding Fault manager issues in our LMS 4 installation.
The original post: https://supportforums.cisco.com/message/3233282
The following menus do not open (error messages are shown instead):
Monitor> Fault Settings> Setup
Monitor> Threshold Settings> Fault
Reports> Fault and Event> History
gunarserdmanis
I just checked the affected menus and it now seems the issues are gone. Could it be that the IPM patch (which fixed SNMP v3 and IPSLA issue) also fixed DFM?
