LMS and time
Wassim Aouadi
Level 4
Level 4
On LMS 3.2, time is one hour ahead, despite that it's set correctly on the host Windows machine.
Any idea?
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
Nael Mohammad
Level 5
Level 5
Search the Windows registry to see if the timezone is defined correctly for this key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TimeZoneInformation\TimeZoneKeyName". The value should be your time zone and not emptyp.
I checked that registry values. It shows "Romance Standard Time":
I checked on Control Panel. The date, time and timezone are correct:
Why does LMS still show a different time and timezone?:
