LMS to ACS integration
Kai Onken
I'm currently using a LMS 4.2.x System and an ACS 5.3 System.
I solved the problem to authenticate the LMS WebGUI login to the ACS Server. But, I can't not find any document, which descripes how I can assing the group roles via ACS.
Kind regards
Michel Hegeraat
Level 7
Level 7
Intergration with ACS is no longer possible or even supported.
You can now specify within LMS what devices a user can see
Cheers,
Michel
